Results 1 to 12 of 12
Thread: hey guys some help plss!!
    Mar 2024
    NOGALES,MEXICO
    17
    Chevy Colorado 2010 5.3
    Colorado stock trans throttle 100 tuned.hpt
    colorado 2010.hpl
    When running normal on street it drives smooth but when i make a stop it sometimes drop rpms too low and turns off.
    going uphill on normal speed car feels like it cutsoff and drops like 400 rpms and feels like it will turn off any help here trying to calibrate something im new. only changes ive made were to eliminate vvt , eliminate engine diag codes it doesnt have bank 1 sensor 2 and bank 2 sensor 2 (oxy sensors ) so i disabled those codes, speed limiter , electric fans wouldnt turn on by themselves so i changed the relay control tables, startup (P/N and in gear), electronic throttle open rate; pls if any of yall can help me keep my car rpms where they need to im guessing the problem can be my throttle and changed it but it reacts the same. The log i did was going uphill u can notice it cutsoff on a certain point.
    Miguel....
    2,973
    The fueling is pretty far off.
    There is a good chance the rest will fall in line when you get the MAF calibrated in a bit better.
    Tuner at PCMofnc.com
    Mar 2024
    NOGALES,MEXICO
    17
    thanks... I just need to get a wideband though i think imma leave it on hold till i get one
    Mar 2024
    NOGALES,MEXICO
    17
    basically this colorado has a 2010 tahoe 5.3 engine tried to set the stock maf calibration of the tahoe and doesnt react so well
    1,579
    I know you have a shop. I hope you aren't tuning customer vehicles at this point.
    2,973
    Quote Originally Posted by Mikeloko View Post
    You shouldn't need a wideband for that. The fuel trims will work.
    And the MAF calibration is really dependent on the tubing.. so the same maf in two vehicles will take different calibrations.
    Mar 2024
    NOGALES,MEXICO
    17
    gstorey i just started on this, some dudes from other city tuned this vehicle and bricked the ecm, I orderd a new ecm for a 5.3 colorado and it came this way with various calibrations that dont even need to be moved. I just disabled vatts for this car and the client returned with those problems ive done nothing but that...
    Mar 2024
    NOGALES,MEXICO
    17
    basically i just know the basics of tuning i know i dont know too much but my dad wanted me to fix problems, i hadnt touched tables that make the engine work differently thats why i need help because i dont want to fck up the engine or anything else
    1,579
    Doesn't match
    Mar 2024
    NOGALES,MEXICO
    17
    well thats why i need HELP!!!!!!!!!!! i didnt drive the car w that maf calib i just turned the car for 1 minute cause nobody helped calibrate it right....
    Mar 2024
    NOGALES,MEXICO
    17
    i put the calibrations back to normal after that
    Mar 2024
    NOGALES,MEXICO
    17
    colorado 2nd log.hpl
    heres the 2nd log after calibrating maf, power enrichment
