Results 1 to 10 of 10
Thread: 2012 Dodge Charger 5.7 rt
    May 2022
    Texas
    26
    2012 Dodge Charger 5.7 rt stk file help
    I have a 2012 charger 5.7 rt i need a base stk file
    gpec2
    os 05156124Ae
    I attached the file pulled for reference the car seems to have had cam headers and MDS delete now it just has long tube headers on a stk rebuild engine any help would be appreciated.
    Mar 2021
    Pompano Beach FL
    272
    1432231282.hpt
    This should be close to work.
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
    May 2018
    Germany
    590
    original.hpt
    This is a stock 2013 challenger R/T AT file. Gives you better performance in a charger by transmission settings.
    I got a 91oct Diabl* file too.
    May 2022
    Texas
    26
    Thnks for the replys.
    Why are most of the stock files out there for police trim packages, is there a performance difference in those the only noticeable changes I see are in the pedal command area and it seems they have looser parameter thresholds i assume to reduce dcts for hard.
    Also f.creek can you attach the diablo file
    May 2022
    Texas
    26
    Took multiple files but i have a somewhat base file
    Could someone look over this and tell me if you think it is good i was trying to build a base file to start a tune from.
    The file has no cat long tube and pedal command turned up and vvt and mds enabled.
    Jan 2022
    959
    i got this
    can look
    May 2018
    Germany
    590
    2013 Challenger AT 91 oct Diabl*
    91oct.hpt
    May 2022
    Texas
    26
    i got this
    can look
    Everything looks pretty similar except the ve tables, spark being .5 - 1* different, and stat up fuel in low temp cells
    Would it be safe to assume the ve tables are different due to different air restrictions?
    And spark being mildly different due to model and performance expectations?
    May 2022
    Texas
    26
    Quote Originally Posted by f.creek-ranch View Post
    91oct.hpt
    Thank you for the file it will help with teaching me what things are getting changed for higher octane fuel.
    May 2018
    Germany
    590
    Don’t care about spark, the knock sensor will cut it. You can log it later.
    VE isn’t active by driving as long as you use th ANN.
