Thread: Logging AFR via EGR issue. No EGR enable setting.
    Jan 2023
    10
    Hello!
    Currently tuning my Open loop SD car and I would like to log my AFR on HPT scanner.
    I am trying to read my wideband via EGR. I have everything set up but am reading 0.00 volts for the EGR sensor.
    I have read that i have to re-enable EGR for it to work.
    Under my exhaust folder I cant find EGR enable or disable.
    Running a 2BAR OS on P01 ECU 2002 F-Body.
    I do have the MPVI3 pro feature set but do not have the pro-link cable should I just purchase the pro-link cable and scrap the EGR idea?
    I also have done the online training for the emissions related course nothings grayed out.
    Attached is a screenshot of my VCM editor and the tune itself. If anybody has any information on this issue or could point me in the right direction it would be greatly appreciated!
    TRANSAM Redline DYNO TUNE GERMANY EGR ENABLE.hpt
    13,599
    Newer version of the software removed it, that's why you can't see it.
    I can see it on my end but I can't edit your file for you. If someone here is nice enough they will turn it on for you can post the edited file.
    Jan 2023
    10
    You are the man thank you so much.
