Thread: Cause Knock Retard only at lower rpm and throttle position under load?
    Feb 2024
    Oakland, CA
    6
    Hello, I am getting Knock Retard only at lower rpm and throttle position under load. so between 2800-4000rpm at like 40-50% throttle. I see between 3-7 degrees being pulled. I have a fairly heavy station wagon with a 4l80e and LS6. I am currently running the stock LS6 timing table. it is only in 4th gear, I don't get any knock if I give it enough throttle to downshift to 3rd.also, its only on the first hit probably until the torque converter unlocks? I tried lowering the downshift 4-3 throttle position but im not sure how far to go? I have 3.55 gears so 2800 is about 75mph, so its right in highway passing lane range which is annoying?
    Anyone have any ideas? I have only been tuning for about a month since getting the swap done. So any advice even the obvious would be appreciated.
    Thanx
    13,604
    Post tune and logs.
    405
    2,365
    What octane fuel are you using?
    Feb 2024
    Oakland, CA
    6
    we only have 91 in my area,
    I will post a tune and log tomorrow, (they are on my other computer at work)
