Originally Posted by
jhbau1000
I'm still working on this garkhul. I have been in contact with HPTuners it appears that turning off the ISS does nothing for changing the way the TCM\ECM calculates TCC slip. Now it did take my transmission shop 4 times to get the TCC to not show a slip using (OSS-RPM)*Gear Ratio = TCC Slip in VCM Scanner. Also on the 3rd time the transmission went in, it stopped pulling altogether. Turned out to be the pump vanes broke and it was no longer pumping fluid.
Now I have put about 1,000 miles on transmission with the P0741 turned off. It seems that when you put it in reverse it takes it a few seconds to engage. I stopped driving it, now I'm waiting to after the holidays to change out the transmission filter and fluid.
I have a 2 more Tune files that is supposed to work with these 13 pin transmission, but I have not tried them. It cost 2 credits each to use the files and you only need the TCM part of file. I'm have been reluctant to try it, because I have bought 2 other files that I was told would work but did not. I will post the files here if you want to take a shot at them. If you do try one of these files let me know please. It sure would be nice to narrow this done so others don't waist there time and money on files that don't work.
