Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: Filtering help needed
    Mar 2022
    Indiana
    3,073
    I'm going to say it again.
    You'll get where you going faster if you filter by fuel trim cell. Things that happen in decel are a good example. Fuel trims can go nuts there but aren't stored and are not important. If they get averaged into your good data it will take you longer.
    You're talking wideband filter, not CL fuel trims filter, correct?
    Mar 2022
    Indiana
    3,073
    My LNF/E69 uses a wideband instead of a narrow band stock, and it stoworks a lot better to use fuel trims than commanded vs actual AFR.
    Exactly what I was trying to explain to another user in a different post. It's not just the sensor, it's also the control algorithm driving it.
