Results 1 to 3 of 3
Thread: TCC Desired Pressure
    Sep 2018
    Norway
    I would like to change some TCC settings for my L20/6L90 swapped 1993 S10 Blazer.
    The engine and transmission are from a 2014 Express van, and it is a E38 ECM.
    I can?t understand the ?TCC Desired Pressure? (TCM 5672).
    Some values are set to zero, and max value is 52. The PCA range is 0-168 Kpa.
    All instructions I have looked at, shows PCA range 0-1600 Kpa.
    I would like to enter similar values as a 2012 Camaro ZL1, where the values are set to 79-1330 Kpa.
    Can someone explain this difference in PCA range? I guess I can?t just copy the ZL1 values and paste it to my tune, as long as the range mismatch?
    Thanks,
    Roy
    Jul 2020
    VIC Australia
    1,204
    That is very odd. I'd fire off a support ticket. In the mean time, you could change some of those values, like flatline the whole table to 70 and see if the tcc responds. It may just be a scaling error.
    Aug 2023
    SoCal
    484
    I can't help with the value shown, but from an hydraulic standpoint, in a stick transmission the maximum line pressure is 2300 kpa and the maximum TCC solenoid output pressure is 758 kpa.
    Robert Moreau
    TransGo
