Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 95
Thread: New computer need guidance already bricked one
  1. #61
    Dec 2019
    Meridian Ms
    113
    Should i try and rewrite the stock file? I did read it with and without the t42 just too have a comlplete with and without tcm.
    Thanks, Tody
  2. #62
    Dec 2019
    Meridian Ms
    113
    Well its fu#$ ed up now. Detect protocol whatever thre hell it is. FML
    Thanks, Tody
  3. #63
    Dec 2019
    Meridian Ms
    113
    Thanks for all the help from everyone. I am going to look at my options and decide what to do. Again thank all of you for taking the time out to help me.
    Thanks, Tody
  4. #64
    8,013
    When you removed the TCM did you jumper the CAN lines back together? 6 to 37 & 7 to 38?
  5. #65
    Dec 2019
    Meridian Ms
    113
    I took it out completely unhooked everything going to it and ran the gmlan wires to the diognostic port. Then tried to write it and went to 51% and couldn't find anymore wiring issues because i bypassed the car fuse box and went straight to battery with switch to the switched power. When that wouldn't work i decided to make a bench harness to make sure it wasn't wiring or anything in car losing power. My power supply is a model SL-11R 13.8 volts 7 amp continous 11 amp at 50% duty cycle transformer. Only thing on it was the pcm.
    Thanks, Tody
  6. #66
    Dec 2019
    Meridian Ms
    113
    My thinking was the tcm OS issue we kept going back to was the issue and i wanted it out the equation all together hoping it hadn't messed up anything already.
    Thanks, Tody
  7. #67
    5BA8
    3,591
    What's the service number of the PCM? Is it posted somewhere?
    email=[email protected]
  8. #68
    1,580
    Try reading the existing file, followed by immediately writing your desired file. If it will read but not write on the same setup then I would think there is a problem with the write file. If it won't read, likely a problem with the ECM or the wiring.
  9. #69
    5BA8
    3,591
    I'd try reading it and then doing a write entire with an unmodified file. Read it out and write entire without changing anything.
  10. #70
    Dec 2019
    Meridian Ms
    113
    Thr service number is 12597121.
    Thanks, Tody
  11. #71
    SoCal
    1,623
    Just as a side note on programming. I personally don't like using power supplies of any kind during programming. I will always use a nice charged Optima I have as a jumper. GM says that the ripple that chargers put out causes programming issues. I personally have done thousands in my decades as a GM dude. Never had a problem but then again I don't use a charger unless it is GM's one specific for programming.
  12. #72
    8,013
    Battery chargers do things, on purpose, because they are battery chargers. Power supplies don't, as long as they aren't cheap garbage. Some better battery chargers have a power supply mode/setting where they can be forced to not do the weird charging algorithm stuff and just do plain constant voltage until you tell it to stop.
  13. #73
    SoCal
    1,623
    When I got a new DSO about 10 or so years ago we had a charger that wasn't doing so good a job at charging. Volt meter said it was good voltage. DSO had a HUGE spike in it. Had a bad diode. Ordered a new one from Mouser and bam. Started to charge great. If I hadn't use my DSO no one would have known it was messing up batteries.
  14. #74
    Dec 2019
    Meridian Ms
    113
    It won't read it but when you try to write entire it will start and go to 10-30% then time out. The first one i messed up won't do anything. The other couple one goes to detect protocol one time and read it the second time. I have the diagnostic port wired up 4&5 to ground at wire 13. I have 12v at 16 and 20. The switched 12v is 19 and 47 and gmlan at 6 & 14 and 27 &28. I have the resistor and between the two data wires on the dtc port its getting 60 ohms. All on J1 plug. I don't know why it times out. I bought a new cable and it won't read the interphase with it or my good cable for my night vision scope, i figured it would be the best since it's a data cord and not just a charging cord. When i got this MPVI3 the cord it came with wouldn't work either not sure if that means anything but figured i would let yall know everything. Also when i'm trying to log my truck it will cut off all the time i just figured it was the plug on the truck.
    Thanks, Tody
  15. #75
  16. #76
    Dec 2019
    Meridian Ms
    113
    Ok i moved the dtc port grounds to 13 alone and hooked the ground #73 to ground on the power supply and write entire to the stock program without the tcm i had and it wrote the whole thing went to 100%. I then cut the 12v switched off but left the 12v batterey on. I haven't done anything else kinda scared to. What should i do now?
    Thanks, Tody
  17. #77
    Dec 2019
    Meridian Ms
    113
    In the passkey section in top left what type of relay is that? Does GM just put the X threw the electromagnetic part instead of /, I see it's not a diode but making sure it's a normal relay and not something i haven't noticed before.
    Thanks, Tody
  18. #78
    1,580
    Looking at this on my phone so may be missing it, but I don’t see passkey anywhere,
  19. #79
    Dec 2019
    Meridian Ms
    113
    My bad it says ecm tcm easykey where the B+ comes in.
    Thanks, Tody
  20. #80
    8,013
    That's just the name of the fuse in the OEM fuse box.
