Results 21 to 40 of 54
Thread: Cold start issuss
    Mar 2022
    Indiana
    3,047
    There's a few of those. Wouldn't happen to have the exact number would you? 218/224 .553/.553 110+0 is the V2, for example.
    Jan 2024
    indiana
    31
    yes that is the exact one, i appreciate you helping with this thanks
    Mar 2022
    Indiana
    3,047
    Alright then here you go. Deka 80 info, and I sanitized the VE a little.
    Use this then post a log, please. Include cylinder airmass, dynamic airflow, injector pulsewidth per bank, and STIT.
    Jan 2024
    indiana
    31
    okay i will write and log this tomorrow i really appreciate it, tomorrow after work ill post it
    Jan 2024
    indiana
    31
    LOG3.hpl
    LOG4.hpl
    It started really rough, had to adjust throttle some for the IAC so first log 3 is the original cold start, log 4 is the after IAC throttle plate adjustment
  6. #26
    Jan 2024
    indiana
    31
    i had to give it throttle to stay running on the cold start it kept dying
  7. #27
    2,931
    Its very rich. It doesn't make sense worrying about IAC counts right now. Get the fueling a bit closer, else you'll bake in extra air you don't need.
    Tuner at PCMofnc.com
  8. #28
    Jan 2024
    indiana
    31
    So I?m fully new to the tuning at all, what would get me to be able adjust that mixture down? I see that they are -30% fuel trims so it?s really rich, and then the o2 is 900mv
  9. #29
    Mar 2022
    Indiana
    3,047
    Adjusting the VE table based on the fuel trims. Tune is setup to use STFT's right now. LTFT is disabled, but there are residual values left. Please use VCM Scanner>Vehicle Controls & Special Functions to clear them. Load this tune and log.
  10. #30
    Jan 2024
    indiana
    31
    LOG5.hpl
    LOG6.hpl
    still had to throttle it to get it started and when in open loop if throttle will die, log 5 is the cold start one, log 6 is after warmed up.
  11. #31
    Mar 2022
    Indiana
    3,047
    It's still pretty far off. Add STIT to the logs, too.
  12. #32
    Jan 2024
    indiana
    31
    How to add STIT
  13. #33
    Jan 2024
    indiana
    31
    I looked for that the other day when you said but I couldn?t find it
  14. #34
    Mar 2022
    Indiana
    3,047
    Specific Parameters>Engine>Idle>Idle Adapt (STIT).
  15. #35
    Jan 2024
    indiana
    31
    its definitely getting better no throttle req for startup, it did die the first startup but it fired the second time and caught itself,
    LOG7.hpl
  16. #36
    Jan 2024
    indiana
    31
    take a look at this, im unsure if im doing it right, but my fuel trims seem closer but im unsure if this is correct still, this is the tune i adjusted the VE table some
    log9.hpl
    truck tune 1_Deka 80_SD_3 (1).hpt
  17. #37
    Mar 2022
    Indiana
    3,047
    Hey that's pretty good. Keep doing it and you'll get there.
    For the dying at startup copy-with-axis your VE table to the Cranking VE table. It'll only do 3 columns, 400, 800, 1200rpm, but a linear interpolation between them will suffice. 1200rpm and up will be the same. Use horizontal smooth 3x between 280-400rpm.
  18. #38
    Jan 2024
    indiana
    31
    okay thanks i appreciate it, so the goal is to get these fuel trims as close to 0 as possible correct? or do you just aim for +-10?
  19. #39
    Mar 2022
    Indiana
    3,047
    Within 5% if you can for VE.
  20. #40
    Jan 2024
    indiana
    31
    is there something to adjust per temperature? it seems like it doesnt run right until it hits 180 degrees
