Page 6 of 7 FirstFirst ... 234567 LastLast
Results 101 to 120 of 136
Thread: 4l80e no 4th unless commanded, no codes
  1. #101
    1,608
    Quote Originally Posted by TransGo Robert View Post
    I did not see any mention of that, maybe I missed it?
    Post 96, #3. last little bit "but B reads 0v".
    I think the pins may be confused still and pin R was grounded. Maybe.
  2. #102
    I have the 4l80e connector pinout in front of me. I grounded pin p. I included that info because I also thought it was odd
  3. #103
    Aug 2023
    SoCal
    484
    Interesting, I completely missed that. Does not make much sense since in M2 and M1 plugged in he was getting voltage but maybe it has a wiring issue as well. Would be best to double check that for sure, all three should have B+ when unplugged.
    Robert Moreau
    TransGo
  4. #104
    1,608
    So with transmission unplugged and nothing grounded, what do you get on "B"?
  5. #105
    Could it be the reason that sometimes I have 3 gears, and sometimes 4?
  6. #106
    1,608
    If you are grounding P and pulling down "B" to zero, but not "C" to zero it sounds like a wire crossed in the harness. If you ground R does it pull down either of the others to zero?
  7. #107
    Checking things now. Unplugged I get 12v to a b and c
  8. #108
    Aug 2023
    SoCal
    484
    Quote Originally Posted by travmac79 View Post
    Good that makes more sense.
    Robert Moreau
    TransGo
  9. #109
    Grounding r pin, I 12v on b
  10. #110
    Grounding p pin, I get 0v on b
  11. #111
    1,608
    Just to make sure I'm clear on "B", that is pin C1-17?
    Did grounding R pull "A" or "C" to 0?
  12. #112
    I take that back. Grounding r pin I get0v on b. Sorry about that
  13. #113
    Grounding n pin gives 0v on a.
  14. #114
    Each time I ground a pin, the other two showed 12v. Could my harness connector have loose or burnt pins causing intermittent stuff? It looked like the internal harness connector had been leaking on it for a while when I got the trans.
  15. #115
    1,608
    And grounding Pin "P" also gets 0 volts on "B"?
    3. With trans unplugged, ignition on, terminal p on the connector grounded, C reads 12ish volts. A also reads 12v, but B reads 0v
  16. #116
    Aug 2023
    SoCal
    484
    You must mean 0V on C right?
    Robert Moreau
    TransGo
  17. #117
    1,608
    At this point it's completely unclear what has voltage when a transmission pin is grounded. Post 114 makes it sound like everything on the harness and ECM is correct or has an intermittent problem.
  18. #118
    1,608
    Only you can determine if your conflicting voltage readings you have relayed are caused by how you are measuring or by damaged harness or connector.
  19. #119
    I could have had a bad connection with the multimeter when I measuredit the 1st time. My old multimeter took a dump this week too when I started diagnosing. The new ones ground probe end broke earlier too but the most recent posts, I am sure that everything is correct.
  20. #120
    1,608
    I think you need to redo the tests in post #83. Anything that doesn't match that chart needs to be remeasured until you are 100% sure that you have accurate readings. Actually anything that returns a zero/low voltage needs to be confirmed 100%.
