6.0 swapped
Hello everyone, recently I swapped my tired 5.3 for a cammed 6.0, the truck runs and drives on the factory tune but does stall at lower rpm. I am looking for a basemap that i can play with to fit my setup, im very new to tuning so I'm learning as I go, if anyone has one they would like to share that would be great. I listed my engine specs below just incase anyone can help !
Gen 3 6.0, factory 4l60e with increased line pressures
Summit racing 8713-R1, 222/232 112+5, .550/.550 Lift , summit valve springs meant for cam
Gen 4 lifters
Factory push rods
Oem head gaskets and bolts
Oem oil pump
TBSS intake , 92mm throttle body with 8.1 injectors.
B&M torquemaster 2500 stall
E-fan swap
Pacesetter 1 3/4 long tubes
3" true dual exhaust with thrush mufflers and high flow cats
Any help / advice would be greatly appreciated,
