I have an 04 5.3 in an 83 Jeep CJ5. It has the P59 PCM. I noticed that the knock counts are constantly increasing at a rate of approximately 2-3 per second at idle and I was getting P0327 and P0332 codes. I couldn't imagine that was possible so I unplugged the connector at the intake and it is still doing it. I ohms checked between the connector and the PCM and everything is correct. I've never seen a shielded knock harness before but it may be picking up something. Are there any other ideas before I split the harness open and separate the knock sensors?
