Started having a random miss that I cant pin down to a single cylinder by disabling injectors and running speed density so no misfire data either. I can see the narrowbands/AFR spiking but not sure if there's a way to figure out which cylinder is the culprit maybe with filtering or something? I have an IAT in the intake and trimmed out all the MAF wiring so I can't just throw one in and test that way. Tried logging currently firing cylinder but it doesn't keep up even at low rpm. Any advice appreciated, thanks!
RCSB V3 - 4L80 - 2BAR RTT.hpt
23-09-16 16-45-04 missing.hpl
