2002 z06. I have no STFT readings with the HP scanner from either for the upstream O2 sensors. I will get P0134 and P0154 after driving about 10 to 15 miles. Cleared codes and repeated several times with same result. I have tried many of the suggestion found searching the forum with no success.
I have a MPVI without the wideband O2 option that a purchased to setup new injectors in my Chevy truck but have not done any tuning otherwise. I plan to purchase the upgraded version with the wideband next but would like to get this issue resolved first. Any help or suggestions will be most appreciated.
Tests performed for the upstream sensors. Checked and tested the o2 sensor signal and heater circuits. Heater has 12+volts with heater ground and chassis ground. Signal circuits have around .450v at both sensors when unplugged.
The HP scanner channel shows voltage for both sensors fluctuating around .450v, but the STFTs remain at 0.00% and never show a change.
Tested the hi and low circuits for continuity from the PCM to the sensors and no open or shorted circuits were detected.
Back probed the sensor wires and at the sensors and at the PCM and have .027 volts key on engine off after sensors heat up. At idle the readings fluctuate to over .350 when I revved the engine and jumped out to read the meter.
The HP scanner shows no changes with the sensors connected or disconnected. Shorting the sensor wires to ground had no effect on the reading.
Also tried the old sensors. Heated with a torch and sprayed brake clean. These test sensors when disconnected showed voltage readings close to 1 volt on a meter, same test connected showed no changes on the HP scanner.
History: I?ve had the car 2 years and blew the engine up last fall that included rods out the side, oil on the exhaust and flames out the left front wheel well and rear of the car. Current repairs included finding a LS6 core, complete rebuild including close to stock forged pistons and rods, stock heads rebuilt with ss valves, Scoggin Dickey very mild cam and Johnson lifters. While the engine was out, removed engine bay wiring harnesses and PCM. Repaired all damaged and burnt wires and checked and resistance tested each wire. All 4 O2 sensors were also replaced.
Thanks,
2023-07-24 2 IDLE.hpl2023-07-24 z06 Read 10.hpt
