Results 1 to 9 of 9
Thread: p015a 6.2 l99
    Jan 2022
    OK
    6
    p015a 6.2 l99
    need help understanding data log i keep getting this code every 30 days p015a
    Jan 2022
    OK
    6
    tune file
    this is after speed engineering longtubes no cats bbk 2 3/4 x pipe and flowmaster 40s and k&n blackhawk cold air intake 2014 camaross
    Jan 2022
    OK
    6
    well ive had 90 plus views but no help
    1,562
    2010 Camaro service manual does list p015a as a valid code for at least the 2010 model year. It does show 13a and 14a.
    SoCal
    1,608
    SoCal
    1,608
    Basically it is your B1S1 HO2S is tired.
    Test I do is hook my DSO and check rich to lean switching rate on a throttle snap. HO2S voltage rises above
    600 MV and falls below 300 MV and switches in less than 100 milliseconds. You can also check it in your Mode 6 data. It updates pass and fail tests and how close they are. Great stuff for diagnosis of Smog check failures. Some of my bread and butter.
    Don't get butt hurt if no one answers you back in 15 minutes. Most of the help that is on here is FREE. Shop rate at the dealer I was at is now $260 an hour with a 2 hour minimum. Lots of good guys here. Last thing you want to do with a bunch of Alpha Male mechanics is complain. We can be pretty ruthless. Funny but ruthless.
    Jan 2022
    OK
    6
    roger that i got on top of myself...
    Jan 2022
    OK
    6
    integral delay airflow mode 1.2x
    proportional airflow mode .90x
    proportional limit 1.25=
    low, mid, high flow .95x
    min rich lean 300
    max rich lean 675
    target idle speed, p/n, in gear 50+ rpm
    these r the changes ive put on new tune are these ok
    SoCal
    1,608
    I usually never mess with the min rich lean from stock.
    You need to fix the HO2 sensor issue first. That can't be fixed with software modification and shouldn't be.
