Results 1 to 2 of 2
Thread: another 'desired throttle area' question
    02 C5 Z06.
    I've seen all the remarks and warnings about freely playing with these tables.
    I notice that I've seen stock files from 01 and 02 P01 PCM's from automatic Corvettes...and I see some of them have much better numbers in these tables than mine (9.7% at 50% throttle position sucks, at least it does vs 24.4%)
    I've seen some people remark they've used the same data in the normal and alternate tables...considering that these use the same TAC modules and PCM's, would it be safe to say these values shouldn't exceed what limits are in my TACM and are suitable for use (considering they are stock values from the same hardware with a different calibration)?
    Indiana
    331
    Lots of people change these but no one can really answer "how much is too much"...basically, if you shift all the data in the cells to the left one cell seems to work well and if thats too sensitive then you can lower the values until you get it where youd like it.
