Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
Thread: Twinturbo chrysler: Can't set torque management
    Tuner in Training Yar's Avatar
    May 2023
    12
    Try a faster polling speed on your spark channel. Also make sure you're logging the correct spark channel. You may want to try several spark channels and see if they report differently.
    If it's reporting actual torque is lower something has to be happening. Air, fuel or spark has to be reduced.
    I did it right away, but it still doesn't help. The algorithm for enabling the editorial remains a mystery
    Chrysler 300C SRT8, 2006 - 6.1 twinturbo 1294hp/1580nm
    May 2023
    12
    I experienced several variations on dragstrip, I liked this one the most. Upshifting is normal, but artifacts appeared in the form of a hump (Highlighted in a circle)
    Of the minuses - big loss of time
    Run 2 (10.5 - 1320).hpl 35 (3).hpt
    Tuner in Training jefo's Avatar
    Jul 2022
    37
    Funny enough, my stock transmission turbo 300 has a similar 2-3 and 3-4 slight rpm flare (not audible in the video below though). I just assumed I'm on the edge of what the transmission can handle, but it seems to happen right after the shift is completed.
    Jul 2022
    37
    Now the transmission has stopped flaring like you showed. Must have needed to just relearn through daily driving.
    Jul 2022
    37
    Just ran a 10.7@128mph with a stock NAG1. The 2-3 shift isn't flaring but it takes a bit to complete now. Other shifts are good.
  6. #26
    May 2023
    12
    I don't understand how you do it. I have 10.5 (145 mph), the transmission is hard. she did not die, but I decided to take it off and check it, tomorrow there will be a result. I stopped pouring more power, everything goes into bad shifting 3-4.
    in addition, I made a new torque converter for stall speed 4000, let's see what happens. while best 60ft 1.9 sec. I know it's sad)
  7. #27
    Jul 2022
    37
    I think your tune needs higher ramp torque values. Thats the main thing that improved mine (I doubled the high end values from the srt cal). Also you have the torque converter locking up in 1st, disable that.
  8. #28
    Jul 2022
    37
    Check the changes and try this one
