Results 1 to 13 of 13
Thread: KOEO Throttle position
    Aug 2021
    892
    Should throttle position read 0 with key on engine off? I noticed mine shows 18.4% and the voltage is 3.55. Once started, the position goes to around 6%ish & 4.22v @ idle.
    Mar 2022
    Indiana
    3,094
    Have you tried this:
    KOEO
    VCM Scanner>Diagnostics & Special Functions> Airflow>Throttle Cleaned
    2,981
    normal behavior
    Tuner at PCMofnc.com
    Nov 2018
    37
    Mine does that and I just assumed it to be normal since there is no IAC, the throttle blade does the job instead.
    Aug 2021
    892
    KOEO
    I have tried it before and didnt see any difference. l went ahead and did it again since i figure there is no harm in doing so.
    Appreciate the info guys!
    8,049
    Like the CKP relearn, the scanner does not give you any info about if conditions have been met to allow the routine to run or if it completed/failed. There should be detailed instructions in your service manual. Not all controllers/OSes/platforms/years have a throttle relearn procedure. The scanner won't tell you if it's available or not, you just click a button and then... guess about whether anything happened or not.
    Aug 2021
    892
    Seems about right lol. Thanks for joggin my noggin, i had not thought to check a service manual for the procedure.
    Tuning Addict
    6,902
    When you key on - the throttle goes through a self check sweep of the motor and position sensors and then parks and it's "parked" position should be "cracked" as it's usually the "neutral" spring tension position. They normally close a little more when you go to crank. Perfectly normal.
    Then as Blindsquirrel pointed out just because it has that feature - doesn't mean it works - even in the GM world they put reset features on some platforms that don't work - I'm sure Blindsquirrel has seen a trailblazer or two that's been really carboned up and he's done a cleaning on only to have it idle at 1500 Only way to reset them is to do a full program even though they have a reset in the scanner. Even some of the Suburbans were like that for some reason.
    ~Greg Huggins~
    8,049
    Hell, the 'reset procedure' in the manual for some of them is to go drive the thing for an hour, periodically checking idle speed vs desired idle speed. Whatever world those guys live in is one where flat rate was never invented because there's no way to get paid for doing stuff like that. Not in any of the shops I ever worked in, anyway. They'd just look at you like you were crazy.
    Aug 2021
    892
    Do you guys ever sleep or at least nap during the day? lol I appreciate the info fellas!
    8,049
    Sleep disorder, my 'days' are 26 hours long. It takes 2 weeks to go all the way around the clock.
    Mar 2022
    Indiana
    3,094
    26hr days. You're on StarTrek time.
    Nov 2018
    37
    hahahahahahahahahahaha I sooooo feel that.... Dating a 30 year old (I'm 44) you'd think would make me feel even older, but she couldn't keep up if her life depended on it....
