Results 1 to 15 of 15
Thread: Gen4 5.3 with truck Norris cam
    Feb 2023
    Georgia
    6
    Hello new to the forum and new to tuning.
    I have no major concerns I had the vehicle dyno at 300 rwhp. But there was a detonation or pre ignition sound at WOT around 5-5500rpm. I took it back to the tuner I don?t know what changed he made all I know is it doesn?t make the sound and it is a turd compaired to what it was. I run premium fuel and I have since done away with catalytic converter insides. I had all of this on a factory exhaust before so I thought gutting cats would decrease cylinder temp and possibly allow me to ?turn it back up? without the pinging. Really need someone who I can send logs and get honest feedback. Again I?ve since bought hp tuners so I can datalog and write. Any experience or help would be greatly appreciated!
    2007 Chevy suburban 5.3 btr truck Norris cam, shorty headers, gutted cats, msd coils, trick flow exhaust valves, Manley race intake valves,Taylor 10.4 wires, 243 heads.
    Tuning Addict
    6,902
    Just post the log and current tune in it here. I'm sure someone can get you going in the right direction.
    ~Greg Huggins~
    Feb 2023
    Georgia
    6
    log about 40 miles plus or minus a few some hwy pulls etc
    Tuning Addict
    6,902
    She's pig rich, burst knock is pulling a lot of timing with wot stomp, no wideband data, no knock sensor data and no tune
    Use these channels and install a wideband if you have one.
    ~Greg Huggins~
    Tuning Addict
    6,902
    Shorter logs focused on the problem area also help to see what's going on.
    ~Greg Huggins~
    Feb 2023
    Georgia
    6
    So shorter logs as in make a few wide open throttle pulls on the log? Also I haven’t yet put my downstream O2 sensor defoulers on yet waiting on them to come in the mail Would that have anything to do with what it’s doing?
    Feb 2023
    Georgia
    6
    attatched files.
    wasn't able to understand opening of the files you attached. additionally, I didn't realize I failed to attach tune. here is a quick WOT data log and the tune that was in the vehicleoriginal tune for suburban.hptwot pull on interstate original tune.hpl.
    Tuning Addict
    6,902
    Once you download the attachment - right click - show in folder - copy file - go to hpt file in your computer to the scanner and then channels section - right click - paste. Should have stated you needed to do that to open the channels. Once your scanner is open - click on open recent channel config - go to where the channels were saved and then select those.
    The above file states original tune - is this what's in it now or what was in it before it was re-tuned for the knock?
    ~Greg Huggins~
    Tuning Addict
    6,902
    OK, so just looking at your log I'm seeing a couple of things wrong from the getgo and I'm assuming this is why it started having knock to begin with. I'm assuming of course that your fueling was off making your ethanol settings start changing. I also assume your original tune file had ethanol spark and why it may have ran better especially after seeing the low timing in the main table with no rhyme or reason for it.
    In this one I disabled flex fuel, changed your PE setting for your oddball stoich setting and changed your timing table to what I know works in these. If it knocks or shows knock then pull some timing, but most likely it's false as I usually run a couple more degrees via the PE timing table.
    Before you start doing any wot pulls though - make sure your fueling is right. VE wasn't dialed in at all - no surprise there, but it's probably going to be wrong with flex being enabled in the tune file not to mention that inj data doesn't look right at all.
    Hopefully this will help you out some and give you what you're after without having to fix every single thing in this one
    ~Greg Huggins~
    Sep 2013
    13
    I know it's off topic, but do you usually see that much BRAF on these 5.3's with the truck norris cam?
    Tuning Addict
    6,902
    Quote Originally Posted by UberVee View Post
    Normally 2 to 6 less depending on where in the rpm's and gear selections you're looking. Like I kind of hinted above - lots of things in that tune don't make sense
    ~Greg Huggins~
    Sep 2013
    13
    10-4, I only ask because I'm tuning one now and the airflow it wants is much less than that so it had me scratching my head. Sorry to the OP for digressing.
    Feb 2023
    Georgia
    6
    thank you i plan on writing this tune tomorrow. is there a video youd reccomend or a quick discription as to how to tune the ve?
    Feb 2023
    Georgia
    6
    worst part is i paid a "professional" 500$ for the tune and took it back to him 3 additional times without charge. but this is what he left me with. really wish I would've bought the program first went through all the steps. probably would have been a little easier of a learning curve. all that for you all to make him soud like a joke but i really would appreciate any bit of tips amd or tricks on what some of the key abbreviations on what i need to know.
    ei
    Sep 2021
    5
    Greg, I have been working on tuning my rebuilt aluminum 5.3 with a 212/218 .550 Lift TSP Stage 2 cam in my 09 silverado, would the timing tables you added work for this as well? Ive been baffled on where to start with setting up a base high/low timing table...we only have 91 octane here. Im catless with longtubes as well if that makes a difference.
    Appreciate the response!
    Alan
