Results 1 to 9 of 9
Thread: SD only tune and Closed loop
    More questions as I get ready to wrap up my tune and return the gear to its owner!
    Once I have my VE and timing table sorted as best I can.
    Do I re-enable closed loop?
    This is combined with re-enabling COT, DFCO, STFT.
    I have read both ways, yes and no dont use closed loop, what do you all say?
    1999 6.0L LQ4 block
    243 heads
    Upgraded rods with LY6 pistons
    BTR LS3 stage 1. - 221/228 .608/.571 112+2
    2010 Camaro SS Exhaust Manifolds
    2006 LS2 Injectors
    Stock truck intake - DBC
    May 2014
    USA
    459
    does it have stock narrowband sensors? Yes, enable closed loop.
    It has both stock O2's
    1999 6.0L LQ4 block
    243 heads
    2006 LS2 Injectors
    8,053
    It depends what the combo is. Big cams with lots of overlap sometimes don't do well if you try to make 'em run closed loop.
    nah nothing radical in my build, mainly a cruiser, its a station wagon after all...lol
    1999 6.0L LQ4 block
    243 heads
    2006 LS2 Injectors
    8,053
    I meant the engine combo. Is it the one in your sig?
    Sorry, yes thats the engine in the wagon.
    1999 6.0L LQ4 block
    243 heads
    2006 LS2 Injectors
    Jan 2023
    Palo Alto, CA
    33
    If you have narrowbands in there you should do it. Closed loop adjusts better for different conditions. And your cam isn't that big so it should work fine.
    2005 Cadillac CTS-V - Tick SNS stage 2 cam, FAST LSXR 102mm, LS2 92mm silver TB, long tube headers and 3" exhaust, V2 rear cradle 3.23 gears
    Perfect thanks.
    1999 6.0L LQ4 block
    243 heads
    2006 LS2 Injectors
