Results 1 to 2 of 2
Thread: LS3 first start
    Jul 2019
    LS3 first start
    I just completed putting an LS3 in my 61 Impala. Almost ready to start it. I have 2 tunes I can start with. One is basically stock, the other has some changes made. The engine is stock other than headers. I'm new to tuning. Can someone take a look at the 2 tunes and give a recommendation which to use? Thanks in advance.
    13,615
    It should fire up if you do a write entire for the VATS removal.
    Just make sure you have no exhaust leaks and your fuel pressure is correct.
