Guys I'd like some input from the experienced guys out there that may have seen the problem I am having.
My car is a H/C car and the dyno numbers and all that jazz are great. What is not great is 5-22% throttle and 60-75kpa load around 2600 to 3200 RPM. The car pops/hesitates in those areas under light load.
I have some logs I can post from HPtuners later but for now I can tell you this. I've made this popping and hesitation get better with less timing in the middle area of the timing map. I've got the timing down to about 17 degree's in those areas and the problem has gotten better but not gone away.
The wideband shows the car is slightly over fueld or right at 14.6:1.
Could I have an issue with my 42lb/bosch injectors?
Do I need some sort of special settings for these injectors?
Is it not related to injectors at all in your opinion?
The popping and such goes away with MORE or LESS throttle but right there in that medium load spot it does it until I hit 3100 RPM. My tune is posted on my site but I'll post the tune and the log from today on HPTuners site in a few hours.
If anyone has seen this before and has some tips on what to look for it would be appreciated! Again only taking out timing seems to help but only so much.
A few things that I've read could be:
Oil consumption? (oil in the chamber?) I do not have a catch can and there is a bit of oil in the intake itself...
To hot of a plug? These are TFS heads milled to be 58cc combustion chambers could the TR6 be too hot for that (11:1 CR)
