Antivirus
The file C:\Program Files (x86)\HP Tuners\VCM Suite\VCM Editor.exe is infected with Gen:Variant.Tedy.274923 and was moved to quarantine. It is recommended that you run a System Scan to make sure your system is clean.
Whats going on here?
Antivirus
i just got the same virus warning
AV programs look not for actual malicious code, they look for code that's similar to known malicious code. I reckon the false detection to real detection ratio is something like 10 to 1, if not worse.
yea cant even reinstall it without it stopping me, ill have to allow the file and go from there
now its all just turned to sh#t cant even install it now, something so simple just stuffing it all up, always says ''verify i have access to that directory'' no matter the permissions i allow or where i put the install file it dosnt get past that and its only for the editor the scanner side loads up fine, even the virus program says same thing when i go to restore the detected file back
What antivirus software do you have installed?
got Bitdefender on there, even disabling it still has the problem, think it may be a directory issue now or something
FYI, first patch Tuesday of 2023 was this week.
Remember when all our 3d graphs turned black and it was all HPTs fault but it really was not actually their fault?
Have you tried to install as administrator? Right click and pick run as Administrator.
my last windows update was 13th and this showed today 15th, was fine last night just this morning boom problem and no updates in-between except prob the virus program which may have blocked the directory from being used as well maby but im not sure how all that works
if i let it go thru and the virus blocks the file same as mentioned by OP then the scanner side installs fine its just the editor side that dosnt, but if i try to allow the editor file then the virus program cant place it back as it dosnt have permission for the file directory even tho ive enabled all of it and same as if i then try to install with the file allowed it dosnt have access to that directory so cant install the editor.exe file properly, damn directories ill have a play for a few days till the next windows update happens then if still not right ill do a refresh/repair of windows
ok just tried installing it again and all went thru as per normal, no windows updates, no hpt updates, only virus has updated
