I?m building a crawler with a 4:1 transfer case. The VSS is in the tail of the t-case.
I?m wanting to use the tow haul when I go to low range to fix some shifting issues, but having a some difficulties with getting it hooked up.
Can I do this without using a bcm utilizing the e38/t42?
Possible to use a momentary switch and bypass bcm?
