quick backstory, I was having issues with my fans not turning on, after countless hours chasing ground wires and doing everything possible to not replace the ecm, I ended up buying a new ecm. I put my tune on the new ecm, the car fired up and after doing a crack relearn things seemed to be going in the right direction.
Here is my issue now. When traction control is on I can drive the car normally, however as soon as I turn it off and try to give it even 30% throttle it goes into reduced engine power and its throwing code p0606. I can clear the code and all seems fine again. So I guess my question is do I have to do anything else besides putting my tune back on and the crack relearn after putting in a new ecm?
2006 ls2, ecs, meth, cam, headers
thank you in advance, any and all help is greatly appreciated.
