Results 1 to 14 of 14
Thread: 06 GTO Tuning Newbe
    Aug 2019
    Nebraska
    8
    06 GTO Tuning Newbe
    I have a 06 t-56 6 speed. K & N cold air intake, speed engineering headers with mid pipe, cats delete, magnaflow Mufflers, tick performance sns stage 2 cam-231/235 | .625"/.605" | LSA111+2. Also rear 02 deleted. Trying to get it to idle better. It does idle rough. I noticed on my log file that my tps is at 20 at idle. Ran perfect before cam. Do not want to drive until I know it?s safe. I also have a can error code (u2101)since upgrade. Also has map sensor code. Log shows map sensor at 9.1 at idle if that helps. No tuners around me that I can trust. Thanks in advance for your help.
    Jul 2012
    Florida
    1,482
    Post your tune and log
    2013 Silverado 5.3, 6L80k 8.8
    Aug 2019
    Nebraska
    8
    Wink What i have done so far
    My tune file is attached. It will idle. Doesn't have a ton of power right now. Thanks
    Jul 2012
    Florida
    1,482
    Several things---First go to Engine--Spark--Base idle and make your chart look like the one I attached. Go to Idle adaptive spark--Overspeed and make all the numbers -5 from 64rpm up. Underspeed---make all the numbers 8 from 64rpm up. Go to Torque mgt --General and open ETC limits. Make the first row across all 0's, all other numbers on the chart make 100.
    Are these the stock injectors?
    Go to Fuel--Power Enrichment and change Delay to 0. Ramp in to 2.00. Go to Temperature Control and COT--Disable. IAT spark will need to be changed but later.
    You should be idling around 17-19 degrees after this. If not, you have too much Base Running Airflow.
    Be sure and make a copy of the file before you make changes.
    Log Cylinder Airmass in Channels, also injector duty, Injector tip temp, -------where is your Wideband Input? I don't see it. You can tune the low rpm stuff with STFT's (Turn off LTFT's) Just don't WOT because boom.
    Aug 2019
    Nebraska
    8
    Thumbs up
    Yes they are stock injectors. I will get my wideband hooked up asap and get those things changed and then send you the log file and tune file when I get that all done. Can you set up the scanner config to log those things please. I am having trouble getting the handle on how to set those up the right way. Like I said I?m am brand new at this. I really appreciate all the help.
    Jul 2012
    Florida
    1,482
    The easiest way to do this is Go to the Bulletin Board home page and look under VCM Scanner. There is a help section--The second thread down is how to set up scanner---you need to know this. Bunch of info there.
    Aug 2019
    Nebraska
    8
    Thank you. I will get this done and get back to you in the next couple days
    Aug 2019
    Nebraska
    8
    New Changes
    I have made the changes exactly how you told me. it idles about 1800rpm. Base idle is set at 850. I am still working on my scanner setup. How do I remove 5% from my base airflow?
    Tuner Dave_In_VA's Avatar
    Sep 2021
    Northern VA
    73
    Go to Engine > Idle > Airflow > Airflow Final Minimum
    2005 Corvette, Z51, 6sp Coupe:
    - TSP ported/milled LS3 heads
    - 11:1 compression
    - Ported OEM LS3 intake & LS2 throttle body
    - 222/230 113 +3, 0 degree overlap w/1.7 rockers
    - Comp 1.8 roller rockers
    - Lift w/1.8 rockers .630/.621
    - Johnson 2110 lifters
    - OEM LS3/7 Injectors
    - LS3/7 style CAI w/blade MAF sensor
    - Std. speed ATI balancer
    - C5r timing chain
    - ARH 1 7/8 headers w/cats
    - C6 Grand Sport MPP Mufflers with NPP in a Box
    - C7 ZR1 Style wheels: 18x9.5, 19x11
    - C6 Z06 Brakes
    Jul 2012
    Florida
    1,482
    What is the mygto tune?? Do you have a scan of the changes that you made?
    Aug 2019
    Nebraska
    8
    Log File
    Here is my log file
    Jul 2012
    Florida
    1,482
    I don't see it idling at 1800. Looks like its around 850 ?? Now you have some STFT numbers to adjust your MAF and VE tables. Be sure and log Dynamic Airflow if you aren't already. When you download a tune, and start the car, it takes a few minutes for the fuel trims to settle in. Let it run for a few minutes and get up to temp before you start logging. That will avoid having a lot of cells that are out of whack. Revving it up when you are trying to tune it does no good.
    Can program some qualifiers into your log to filter out low ECT and transients as well. Once i learned that my life got way better ha.
    2006 GTO 403ci lsa heads kooks long tubes corsa ss exhaust OTR intake HPTuned
    2010 GMC Sierra LMM Duramax. Exhaust and tuned
    Aug 2019
    Nebraska
    8
    MAF Error Graph
    cant get my maf graph to work for error reporting
