okay guys im out of options. I know youve seen this 1000 times.
so i had a stock 98 c5 6spd, i bought an installed A&A TI 3.6 supercharger kit, while i was installing that, i also installed ls2 timing chain, melling high flow oil pump, water pump, api harmonic balancer, BTR supercharger cam, push rods, upgraded trunion, #60 injectors, wideband, 4.10 gears, catless straight pipe exhaust, headers, double spring valve springs,50mm blowoff valve
so after i got everything installed, Andy@ a&a superchargers sent me a base tune so that car could atleast drive. all was well as for it starting but it had some imperfections. So began watching videos AND READING a ton. Im new to self tuning but after a extremly costly run in with a shop i just dont trust anymore. So as im following along with these "step by step" videos. i then discover i needed a 2 bar map sensor. i purchased a cobalt 2 bar maf switched the os to 2 bar speed density and now i cant manage to figure anything
so heres a couple things the car is doing
running SUPER SUPER rich
fans not kicking on
only builds 3-4 psi boost.
hptuners wont show all the PIDS
takes way way to long for idle to kick down once come to a stop
boost studders up top like cha cha cha cha cha cha i dont know how to explain it better. its nothing like it should be.
newest tune 1.hpt
attached is the Tune. id love to find someone who would help me via text phone or email. Make adjustments to the tune as im clueless or how to actually do anything. six3six2498810
