Results 1 to 5 of 5
Thread: fell on its face
    Aug 2021
    887
    fell on its face
    just as the title states. At around 2600rpm when i give it a full-on pedal stab, it packed its lunch and went home! now i can give it a quick half throttle stab and it does ok. im thinking that it may be timing related. With that said, im not sure that my Spark Retard histogram is set up correctly. If so, how should i view it in order to copy and paste? average? counts? + or -? what is the best way to go about tuning the gen 4 timing tables High/Low Octane, and Idle Spark Advance?WOTcutoutmaf.hplnew tq tablesfafm.hpt1.hpt
    Tuning Addict
    6,888
    Disable your tip in limiting for etc. The only obvious place I saw in the log where you went full pedal, throttle went full throttle and then cut to 70%. I originally thought traction control, but you have that all off in the tune then saw your tip in limiting was still the only thing really stock other than some other trans parameters which you might also want to change. The 6 on/off torque switches above the transmission torque settings you might want to put back to stock. They can on occasion cause side effects. Also under spark retard - you tip in settings there too - 0 out v8 mode...
    ~Greg Huggins~
    Aug 2021
    887
    Ok. disabled tip in limit for ETC, put the 1-6 Max torque settings back stock. im not finding v8 mode under Spark-Retard
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    Maybe this
    Aug 2021
    887
    Thank you! Ill get it done!
