Results 1 to 10 of 10
Thread: Idle Tuning with NW 102mm DBW
    Jul 2018
    4
    I could really use some help here. Been beating my head against the wall for a few days now. Build is a 2005 Silverado with a built 416, FAST 102 Intake and NW102 DBW TB. I am at my wits end getting this thing to idle and rev up. I have gone through the internet every night working through the ETC Scalar but I have to add so much airflow to the RAF tables to maintain idle. When I blip the throttle itll rev up and just immediately die. I hope someone can look through the tune and help me see where i might have gone wrong and help point me in the right direction. Thank you for any and all insight.
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Goto Airflow (tab) > Electronic Throttle > and on that section, copy Desired Throttle Area Normal and paste that WHOLE TABLE into Desired Throttle Area Alternate, flash it, and then report back. This will be a yes or no fix. Base airflow and scalar should be set back to reality at the same time.
    Steve Williams
    TunedbyFrost.com
    Aug 2009
    Calibrating
    3,379
    Most the time with super higher RAF numbers and the ETC scaler is adjusted 7200 or similar place the ETC back to the stock and the RAF will become lower and more accurate
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jul 2018
    4
    Evening, I went ahead and did as suggested and it still does the same thing. Is there any way to test the throttle body to see if there is something wroong with it? Ive tuned for larger TBs before and have never had this much drama
    Jun 2007
    Finland, Europe
    550
    This is GenIII stuff, so ETC scalar is different.
    Quote Originally Posted by dylweed89 View Post
    You may have an air leak. Check that first.
    Aug 2009
    Calibrating
    3,379
    [QUOTE=Pekka_Perkeles;665052]This is GenIII stuff, so ETC scalar is different.
    Yup haha, had gen 4 on my mind
    14 Gen 5 Viper
    Jul 2018
    4
    One of the first things I did was check for an air leak. Unfortunately there wasnt one. I just installed a LS3 throttle body and scaled it accordingly, same issue. Starts and immediately dies unless i crank the RAF numbers and scalar to unreasonable values. Everytime I flash it I also lose connection with the TAC module code which throws it into Reduced Engine Power and a "battery not charging" indicator on, which is weird because the voltage is reading 14.0v when its running.
    Aug 2009
    Calibrating
    3,379
    Just clear DTCs before starting some of these OS will get a throttle actuator code and be in REP upon flashing
    14 Gen 5 Viper
    Jul 2018
    4
    Sorry I should have added that if I clear the DTCs i dont have another issue with it until I rewrite.
    Mar 2011
    Ripley, MS
    1,865
    That's a very common issue on the P59 computers. Just clear the DTC's each time and you'll be fine.
