Results 1 to 8 of 8
Thread: 2020 Ram 5.7 dies when coming to a stop
    Apr 2021
    3
    I have a 5.7 hemi with a comp cam, headers, and cats deleted. Had someone make me a base tune and the truck now idles and accelerates great. The problem is when I decel it won't stay running it starts back up easily, but when rolling to a stop it dies. Does anyone have a idea where to look or have a 5.7 with a cam compare file? Thanks!
    Aug 2017
    Quakertown PA
    483
    Quote Originally Posted by BobbyLee View Post
    need some more info, which cam, do you have a current log file ? do you have a tune file we can look at ?
    there are some very helpful people who will help just need a little more info.
    G3 Hemi Videos
    May 2021
    12
    mine did something very similar, after i got my wideband working i found the truck was running to lean in the same condition and it would bog sputter and die. slap it in neutral and fired right up. Not saying this is your deal but could be related, also i raised VSS idle speed to 5 mph between those two things i no longer cuts out when stopping or idle hunts at stops. Just ideas your probably better off waiting for a more experienced tuner.
    Sep 2020
    41
    Try increasing your drive idle speed, you can also try changing you friction table in the low rpm range.
    May 2018
    Germany
    590
    to be sure its not a lean condition, disable dfco .
    you need a wide band…
    Sep 2020
    41
    Sounds like a lean condition. What worked for me was to increase the ECT VE modifier for coolant temps below 40deg. C (as it was usually the first start that was the main issue) and halve the idle spark torque PID values, as well as bump the idle rpm slightly.
    Apr 2021
    3
    I got a wideband installed and have everything set now and runs amazing! Thanks everyone for the advise!!
    Mar 2021
    Reston, VA, USA
    13
    What was the final solution?
    I?m having a similar issue with my Jeep JK. Full length headers and hi-flow cats
