Hey guys, would anybody be able to help out with a strong tune for a VE Commodore L98 6.0L, has had a Cam, attached is full HPT read and cam specs,
thanks
thanks
That's a pretty mild cam for a 6.0L, so it'll be easy to get it to idle and run properly.
Here's a quick synopsis of the steps that will get it running.
1. Go to Engine>Airflow>Dynamic tab and lower the High rpm disable/re-enable to 400/300 respectively.
2. Go to Engine>Idle>RPM tables and Add 150 rpm to the four idle rpm tables.
3. Go to Engine>Idle>Airflow tables and add 3.5 gms/sec to the Airflow Final Min table
4. Go to Engine>Idle>Airflow and increase the startup airflow by 25%.
5. Go to Engine Diag>Airflow tab and change Min ECT for P0101 to 256, and change Airflow Correlation RPM from 800 to 8000.
6. Go to Engine Diag>Misfire tab and change Min misfire detection enable to 2500 rpm.
That'll get it running nicely until you have time to get it to your tuner.
..........One question mate are you going to tune this yourself ? and want some help or advice/learn?...or do you have a tuner in mind thats going to tune it for you, cause without being negative bud good luck finding someone on here to supply you with a good tune especially if you are taking it to a tuner etc...
