Results 1 to 3 of 3
Thread: should drive-by-wire accelerator pedal position be 0% when not depressed
    Jan 2007
    34
    & if not, is there a way to calibrate it
    mine likes to hover around 4%
    13,615
    Drive by wire as in electronic or as in a cable throttle body??
    The electronic throttle will never read zero because the blade is always open to run the engine. Probably around 10-15% at idle. A cable throttle body should read zero at idle.
    Jan 2007
    34
    i have an electronic accelerator pedal
    & just to be clear, i'm referring to the accelerator pedal position, not the throttle position
    i just checked over my last scan & it read 0% prior to shifting into gear
    it wasn't reading below 4% when i posted this thread & i made no changes to affect the pedal
    odd
    sk
