Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: E38 VATS disable not working
    Mar 2011
    Ripley, MS
    1,865
    Don't forget to Disable the Starter diag under the System tab. I checked your tunes above.
    It was not disabled. See the pic below. You are welcome to email me your latest file.
    Nov 2012
    SF Bay Area -> Wellington, NZ
    66
    Quote Originally Posted by Pitbull View Post
    Is the version of the editor you're using now the same as what you were using back when you had done it without issues before? I 2nd it sounding like a bug in the editor.
    I?m definitely using a newer version of the software now, but I don?t know to go back to an older one unless someone has a copy they?d like to email over.
    I put in for a support ticket, but it?s been over a week.
    Nov 2012
    66
    I did go back an make sure the Starter Diag was disabled and did another write entire. Still no go.
    Nov 2012
    66
    Support is of no help so far.
    Doesn't work in any combination of factors if I Write Entire or Write VIN/Tunerlock/VATS or Write Calibration. Doesn't matter if I flip one switch or all of them. Doesn't matter if I save it first and reopen it. Doesn't matter if I don't save the file at all before flashing it.
    The only way I can get an ECM to disable VATS is if I write entire with an entirely different ECM's tune that I know for a fact has VATS disabled. But I've bricked two or three ECMs this way now, and it basically forces me to start from scratch if I've done any calibration work prior.
    Is there something I'm missing here? Why won't these Gen IV ECMs turn off the VATS? It's literally the only part of the ECMs I can't get to take..
    405
    2,378
    If you want to ship me the ECM I will look at it for just the cost of return shipping.
  6. #26
    May 2023
    Delaware
    60
    What version are you running?
  7. #27
    Jan 2023
    NY
    273
    2 year old thread...
