Thread: Wideband Oscillation Voltage
    Mar 2016
    27
    Currently working on tuning a 97 Tahoe with a HT383E and a 411. I finally bought a wideband (Innovate 3918) to put in the truck, installed it in place of the DS o2 for the time being until I can get a bung welded in, tapped into the fuse box by the door for WB power, and grounded to the metal dash support. I am having a problem with the wideband voltage oscillating pretty drastically when reading into HPTs. If WB gauge is at 14.7 it will read ~13-17 on the analog out, but seems to average out normally to make proper adjustments. The gauge itself is consistent. I found one article mentioning that the input voltage is the issue due to the analog out being relying on a constant input on a constant input but I don't have any issue like this in my other vehicle with a Glowshift WB. I'm looking for some solutions for fix this or what may be causing this issue. Not sure if it's me, or something wrong with the WB I bought, or if this is normal (which I don't think it is).
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    Are you using MPVI (1) OR MPVI (2)
    Not sure it makes much difference... I know ground loops are a big concern, everyone recommends using one ground point for everything (sensor, WB, interface connection)...
    If you still have issues there are ways to create an offset (transform) your wideband to compensate for bad grounds and harness noise
    Mar 2016
    27
    Quote Originally Posted by dhoagland View Post
    It's the MPVI 1. I added a small capacitor on the gauge input as well as between the ground and the gauge analog out on the MPVI. This helped a bit (mainly the one on the analog out side) but didn't solve it completely. It just looks like I lot of electrical noise in a log so I'm going to just run a wire straight from the battery and see if this solves it.
    Australia
    2,003
    the wideband ground or signal ground must also go to the same scanner analogue input ground or it can cause issues, if u ground it to the dash and only have the signal going to hpt it will cause issues
