Results 1 to 6 of 6
Thread: 2019 C7 Corvette Z06 tune needed
    Jun 2020
    5
    Question 2019 C7 Corvette Z06 tune needed
    Hi all, I'm trying to see what (if any changes) were made to the fuel system calibration. I'm curious since I read the 2019 C7 ZR1 and 2019 C7 Z06 had a low side fuel pump added that has a higher fuel volume. So, if anyone has a stock tune for that year it would be really helpful. I checked the HP Tuners repository but there aren't any. Any help is appreciated. Thanks.
    May 2003
    South FL
    1,406
    [email protected]
    Owner/GM Calibrator
    Jun 2020
    5
    Many thanks!
    Jun 2020
    5
    Just took a quick look and it appears there was no calibration difference between the two in low side fuel pump areas. Do you also have a tune file for a 2019 Z06 (automatic preferably)? The ZR1 tune gives me confidence but I prefer to be thorough. I'm trying to figure out if the 2019+ low side fuel pump which is used in the 2019 MY C7 Z06 and ZR1 requires a calibration difference or if I can just stick it in my car with no calibration changes. It's supposed to flow 20% more volume according to comments by Tadge Juechter.
    Dec 2015
    Miami,Fl.
    292
    It does flow 20% more. You'll run out of low side at the same time you run out of high side which is not a bad thing.
    2023 Ford Maverick 2.0T AWD
    Apr 2005
    Sugar Land, TX
    1,198
    Here's my 2019 A8 stock tune. As we know the TCM does not read without being unlocked my HPT.
