Results 1 to 9 of 9
Thread: 3.4 grand am
    3.4 grand am
    How much TQ management can I remove from a 3.4 grandam without killing the transmission? I am thinking about 50%? Also any advice on shift changes?
    Advanced Tuner gman4dx266's Avatar
    Jun 2006
    Cape Coral, FL
    860
    You can probably disable the engine TM, but without a kit installed in the trans, I'd leave the shift torque reduction in there. You can reduce it, if you're so inclined, though.(Since you're new, just know that I figured it out the hard way. lol!)
    Advanced Tuner xonelith's Avatar
    Oct 2004
    Whitby, Ontario, CANADA
    408
    I may have a factory freak, but I've disabled all TM and increased shift pressures and I'm shifting at 6800rpm all on the stock tranny. I seem to be ok (obviously not recommended) and I've driven over 100 000km like this.
    Good luck!
    All Motor 2001 GA GT1
    Jun 2006
    Cape Coral, FL
    860
    That or I had/have the factory freak(s). My first went out @ 7K miles...2nd one aint feelin too hot anymore too and i got some tq reduction before the shifts in there too..
    Guess they just dont make em to hold up to teen drivers, eh?
    Ok I upped the Engine TQ from 380 to 420 on the Engine->TM->General-> Max TQ vs Gear and on Engine -> TM -> Max TQ vs Gear vs Rpm
    That too much.. the car seems to stay in one gear alot better
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Quote Originally Posted by turbo lcc
    On the V6 cars, I remove all the upshift & downshift torque reduction after I get the shift pressures set up so there is no slip at the wot upshifts.
    Russ Kemp
    ok.. what pids do you monitor to adjust shift pressures? or do you just up them by X amount?
    Dec 2005
    Regina, Sask.
    4,214
    Check some of my posts about increasing trans pressures by adding 0 to 60 psi using the Interpolate Between Horizontal Bounds method.
    Russ Kemp
    Feb 2006
    Canada
    1,963
    Also, Xonelith, has a bin in the repository that has some of the stuff you are looking for. Search for GA's with all model engine and trans and a couple will come up. Be sure to review his write up and use the parts you want. You could try the full file and remove the stuff that you don't like as well
    http://www.hptuners.com/customers/tune.php?
