Here is what I want you to do for the VE table.
Copy the 100kpa row of the VE. Then paste that row into the 315kpa row. Now with the tool at the top put 10 in the box and add 10 to that row. Now highlight from 100 to 315kpa, then click interpolate between vertical bounds. This will create the VE for you. The way the VE is right now is about 100-120% too rich in boost, it does not need to scale up like that when you have larger injectors/fuel system.
There is a very strong chance that the VE will still be too rich with how large your injectors are. This is where using the wideband error against the commanded AFR/Lambda comes into play. That error will tell you where the VE needs to be leaned out or made richer. Sometimes just a big global change is faster than small sections. If it's rich all over just minus 10-15% from everywhere and start over with another log. This way there isn't tons of back and forth, hand smoothing etc etc.
