Results 1 to 6 of 6
Thread: EOIT tuning Spreadsheet calculator question
    May 2018
    31
    This is my first attempt at leveraging the EOIT tuning spreadsheet, and I wanted to see if anyone can validate my approach. In the lower < 2000 rpm regions, I'm trying to remove as much fuel smell as possible, then above that bring the EOIT close to IVO Peak, then taper down a bit over 4k RPM for safety and atomization.
    Cam specs, 288/303 @.006"
    LSA113 +5
    Centerline 108
    Questions:
    1) Are my boundary targets ideal?
    2) What data points do I use for the Normal ECT table?
    3) Is zeroing out the Normal RPM table an acceptable approach?
    Thanks.
    Screen Shot 2020-01-30 at 4.01.09 PM.pngScreen Shot 2020-01-30 at 4.01.28 PM.png
    May 2018
    31
    Updated EOIT targets on spreadsheet. The targets seem to be in line with the documents recommendations, but I'm confused on how the Normal ECT adders impacts those targets.
    For example, if the boundary at X RPM = 600, and my Normal ECT Adder is 80, does that make the true EOIT 680? If so, do I need to reduce my boundary, or does the ECU do that automatically? I'm just not sure of the impact.Thunder Eagle INJECTOR TIMING TOOL GEN IV - Black Charts-FRCv21.xlsx
    Australia
    1,998
    boundary is the final wall, the other ect, rpm add to before the boundary so the 600 would be less the 80 so 520 eoit, raising boundary number delays injection, or lowering the ect, rpm delay injection, this is where its best to set boundary to all 520 then zero out the rpm table, then lower the ECT until idle goes better (richer showing more fuel getting in chamber) then once idle stops going richer leave it there and remove excess fuel in VE VVE MAF what ever u are using, then u have a base point so then just use the boundary above idle to dial in cruise and wot just keep any adjustments smooth, just dont delay it too far too low as u will have a point where u start to push intake back out when piston is on way back up before IVC point, also depending on pulses within the manifold it can be best just where it works for your setup so if its better in the opposite direction thats fine just do what works for your setup as there is alot of dynamics going on
    May 2018
    31
    Thanks!
    This just changed my direction too, 07GTS!
    ~Ryan
    Charleston, SC
    Tuning Addict
    6,883
    What he said
    Also use throttle snaps - this will let you know if your too advanced or retarded - looking for good crisp, quick revs...
    ~Greg Huggins~
