Will the MPVI with the latest BETA *READ* a JTEC?
Just for giggles I tried reading my Liberty controller which before said was unsupported but now it sees the PCM and TCM. However, it can't identify the controllers automatically so it can't see the vin which must be entered. I did manage to pull a read but had to manually select the controller type JTEC+ which I am sure was incorrect. That would be slick if I could start modding the Liberty.
Liberty.hpt
Nevermind, the read did not take. Just checked the file again and it did not work.
You can't use MPVI1 as VCM beta software looks for the MPVI2 interface and internet just prior to the read.
This has me confused:
03 Ram 1500 SRT10 8.0
03 Ram 1500 SRT10 8.4
Didn't the srt10 come out in 2004?
What is a 8.4, it's a 8.3. Also the 8.0?
Is there a typo here?? Thanks
Awesome!!! Have some viper friends that will love this
Email Tunes, [email protected]
15 C7 A8 H/C 2.3 Blower/PI
14 Gen 5 Viper
I am a gen 2 viper guy and just downloaded the beta and looked at the tune. I have a couple questions though, the fuel table resolution is only 9 rows, in the future will we be able to expand that for us boosted people. Also 2 bar map support?
Any reason why is not listed the Jeep WJ (Grand Cherokee 4.7L V8) 2004 model year? It shows up to 2003 model year, and the Wj was made up to 2004 year. yera 2005 + was changed to a WK serie (new Grand Cherokee).
I hope you guys at HP make this go from beta to official lol, just got my mvpi2 and pulled the stock file from my 2001 Dodge Ram 1500 5.2L and everything went great from what I can tell.
Well I just ordered it for my 2000 Viper through Unleashed tuning. Hopefully it will be here in a couple days and get to mess with it. I am guessing it will be supported a lot better than SCT provided. In the future I would like to see options like 2 bar tuning or OS upgrades.
does Ngauge will work for JTEC - RAM SRT10 2004?
I don't believe we have any plans to offer custom operating system support for these applications, sorry guys.
Is that even possible? I remember on OBDI systems that was the problem when you tried to go boosted the fuel table lost resolution. I mean isn't that like asking to expand the fuel table row/column on GPEC2A controllers. Or is my thinking so outdated?
On the GM vehicles hptuners have a custom OS you can flash that changes some of the tables to incorporate 2 bar or more for boosted applications.
Speaking of that, you can't even change the scaling to go above 105pka in order to use a 2 bar MAP at all.
I don't see any tables for barometric correction or map scaling, but I don't own an MPVI2 yet, so I'm just looking through MPVI glasses. Maybe there is more that I can't see?
you can use a 2 bar but you have to trick the ECU. You cut the MAP values in half so that 50kpa is acctually atmospheric pressure and 105kpa is around 15lbs of boost. It basically cuts the resolution in half so that the first 4 columns are n/a and the last 4 columns are for in boost.
I get that, but you can't change the 105 tag in the row axis to anything higher than 105. As far as I can see, you also can't do anything about barometer correction based on MAP. I don't beleive the JTEC uses a separate barometric sensor - I think it uses the MAP during KOEO.
Check it out...page 10.
https://techauthorityonlinedemo.extra.chrysler.com/service/mds2002/workbooks/en_US/8169999128.pdf
Man I wish this would work on my 2002 liberty. I think the PCM is a bastardized JTEC version but can seem to find more info on it.
