I'm putting in 60lb injectors this week. I have a maggie running 11lbs of boost and meth. Can anyone guide me on what settings I will need to tweak? I am assuming that I will need to modify the values for "Flow Rate vs. KPA" (not sure exactly by what values). How about the following?
Offset vs. Volts vs. VAC (increased from 49.50 to 52.00)
Short Pulse Limit (currently 4.0)
Short Pulse Adder
Min Injector Pulse
Others?
If anyone has an tune file with a maggie and 60lb injectors, I would love to compare. I posted my current tune file to www.hintzworld.com/gto/sdgoat_20060923.zip, just in case anyone wants to compare, critique, laugh at, etc. This tune is based on:
Factory heads / cam
Maggie @ 11psi (42lb injectors)
SLP LTs with Maganflows
Meth injection (currently 50/50, but planning on going to 75% meth at next refill)
Thanks!
