Results 1 to 2 of 2
Thread: First timer - writing to new car/MPVI 2
    I have a couple noob questions.
    I own six credits total.
    4 assigned to the Dodge ZF8HP - TCM presumably
    2 assigned to the Dodge GPEC2A 2018+ - PCM presumably
    Unlocked PCM from HP Tuners - as per instructions I have cleared DTC's
    MPVI 2 with latest scanner/editor.
    I'm have looked and looked and tried to understand the licensing but I'm still a little confused. And with this license selector confirmation screen using an exclamation point - TWICE ("..cannot be undone!" and "..will not be refunded!") I figure it can't hurt to ask.
    Like I said, I have 6 credits and an unlocked PCM with an MPVI 2. I have made a minor modification to the base tune that I would like to write to the vehicle. I would like to make many changes, this being the first. Do I need a credit for each change? Or is the essence of this message that once I write using this MPVI 2, with these particular credits to this particular vehicle they are locked to together?
    Bottom line, I want to write to this vehicle MANY times, am I able to do that with this combination?
    Thank You
    Gary
    28,313
    Once you've licensed the file for the vehicle you can write it to the vehicle an unlimited amount of times.
