If the Intake Cam Des Angle and the Intake Cam Angle are not the same, then somethings wrong, right?
I found my 2009 5.3 Silverado to have its Variable Camshaft>General;Camshafts set to "none" and no activity when logging the des angle or angle channels. Then I changed from none" to "one" and the Camshaft Des Angle started reading values 0-22ish but the Camshaft Angle channel always stays at 0. There is no check engine light.
I dont think my camshaft is moving. What do you think?
Thanks!
Robert
