Results 1 to 20 of 21
Thread: Autostick up shift in NAG1 / WA580
    Jun 2018
    Dubai
    62
    Ive tried everything to diable the autostick up shift for NAG1 / WA580 in jeep wrangler and no luck in doing that
    Anyone who tried it and been able to do it here ? HELP !
    Mar 2009
    S. Florida
    583
    You've done this? Transmission - shift general - autostick: set to disable
    Jun 2018
    Dubai
    62
    this is the stock file of the car i coudnt understand how to disable it
    help please
    Mar 2009
    S. Florida
    583
    Quote Originally Posted by Alshuwaihi View Post
    help please
    You have auto upshift and autostick WOT enabled
    I have the latest beta, so some things moved around
    Go to trans section
    Transmission - shift general - autostick: set them to disable one at a time and see if that is what you are looking to do.
    Jun 2018
    Dubai
    62
    Quote Originally Posted by coanan View Post
    Go to trans section
    i also have beta but it seams what option you have is different from mine
    Jun 2018
    Dubai
    62
    Mar 2009
    S. Florida
    583
    Guess this tuning software is not all the same, I don't see the autostick option in yours. My trans section has a lot more options. Beta 4.1.159
    Jun 2018
    Dubai
    62
    Anyone from HP tuner can solve this problem?
    Jun 2018
    Dubai
    62
    Help please
    Jeep wrangler 2012 automatic, sprintex supercharger, 9lbs of boost, 4.5" lift, fox 2.5 internal bypass shocks, 4.88 gears, 37" tires,
    Ford Mustang Shelby gt350 2017, airraid air filter, jlt catch-can,
    May 2015
    1,908
    update your version of HP Tuners, and reread your vehicle, the switches will be there. Make sure your settings are to advanced, as well.
    Jun 2018
    Dubai
    62
    Quote Originally Posted by 06300CSRT8 View Post
    How to change the setting to advance?
    May 2015
    1,908
    EDIT>VIEW>Advanced
    If its basic, after selecting advanced you will need to close out and reopen the tune to get the view to show advanced mode.
    Jun 2018
    Dubai
    62
    EDIT>VIEW>Advanced
    thank you
    i will try the new options today
    Jun 2018
    Dubai
    62
    I tried to disable the autostick wot and auto stick upshift and no use the car still upshiting on its own ��
    i have been having the same problems and more the latest update to put it nicely is shit so hp but something is not correct
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    I have tried every combination of Auto Stick disabled/enabled. And still will upshift automatically. The only way to prevent the auto upshifts, is to put the vehicle into sport mode if it has the button. And even then, it will upshift after hitting the rev limiter.
    Russ Kemp
    May 2015
    1,908
    Guys - you cannot override the TCM limit setting, no matter what you do with the other settings.
    The way a MTCM used to be setup, and most of the early 2006 EGS 52 TCMs, was the engine cutoff rpm limit was LOWER than the TCM limit, and the enable auto shift was set to disable. This would mean you hit your engine rpm limit and never shift, you can sit there all day sitting on your rev limit and itll never shift. SOMETIMES if you managed to really bang hard PAST your engine rpm limit you can just touch the TCM limit and it would shift.
    If you want to disable autoshift entirely, set your TCM limit rpm about 500rpms HIGHER than your engine rpm limit, and set the TCM limp offset to about 500rpms. This will leave you hitting your engine rpm limit every time with no shift when in Autostick.
    Jun 2018
    Dubai
    62
    i did that 1-2 the gear change on its own but for 2-3 the gear did not changed
    bu 7amood tune number 1.2.hpt
    Was this ever resolved ?
    Oct 2020
    25
    we must wait , I have send the solution at the tech ,or you can set the sitch at 16 absolute value the switch with winols
