Trying to figure out whats the best gearshift stratergy for getting down the drag strip as fast as possible.
My VE ute (as per my sig) was shifting in the .3 second range, I have been able to get those down to .15 to .10 but shifting that fast the car seems to have trouble bring the RPM down fast enough and its easier for it to break the tyres loose. I still have stock torque managment and I can see timing being pulled in the logs.
Attached is a log done on the street with my drag radials on. It only has and intake, LS7 MAF and 3.46 diff gears so its doesn't have a lot of power.
It ran 12.55 with the .3 shifts, haven't run it again since I started playing with the shift times.
Would I be best to keep the shifts faster and let it break loose on the gears shifts? or should I slow the shifts down to prevent the wheel spin? or is there a way to get it to bring the engine down faster to match the tyre speed?
1.013 Trans short log.hpl
GXP62L TUNE 1.013 Blend.hpt
Transmission runs.Charts.xml
