I went out today on a rolling dyno after making some changes (thanks jsllc!), and I noticed few oddities while logging and adjusting the tune. Does anyone have any ideas?
Part throttle is LEAPS AND BOUNDS better!!! During WOT pulls, I noticed the following:
1) Air Calc Mode will sometimes switch sporadically from "Normal" to "Hi Speed" to "Unknown" somewhere around .88g Cylinder Mass (~7,800Hz; MAF Hz is still recording despite being failed). Almost like clock at .88g on every log from today.
2) Again, although the MAF is failed, the Hz is still recording. This isn't that unusual as long as it doesn't take the readings into account for fueling, but during a few runs (not all) the MAF Airflow would calculate until WOT was achieved then would go to 0lb/h. Very sporadic when it would just start producing a mass flowrate.
3) During the same runs as mentioned in 2, something weird would occur...
1st pass where it was noticable - "WOT4_weird". It occurred just shy of 4,800 RPMs (~8,000 Hz) then the cylinder air mass would drop to 0g. This would result in a spike of advance then followed by knock. Almost felt like the engine just shut down for a split second then would kick right back on.
2nd pass (WOT5_weird), which was the following WOT pass ~3min later. It occurred right at 4,900 RPMs (~ 8,360 Hz), and the cylinder mass dropped to 0 shortly afterwards.
After this happened twice, I decided to take it to the house.
I am puzzled, but it's almost like it's referencing my something else (linked to the Air Calc Mode issue?), which is leaning it out severely. I still don't feel like everything is failed correctly while I am trying to tune the VVE. The car is definitely responding to the adjustments I am making so there is a silver lining to all of these trials.
Again, I am open to any ideas or suggestions!
V6.3_VVE_MAFFAIL .hpt
WOT3.hpl
WOT4_weird.hpl
WOT5_weird.hpl
Main.Channels.xml
Thanks!
