So i'm back trying to tune my MAF table. I've installed a recirc bpv with the traditional draw-through MAF setup.
I'm a bit confused of the relationship between the injector setup & the MAF calibration setup. First of all i've got everything set up for 60P injectors from the guide, although I really have no idea what the actual flow rate of these injectors are. I also have my tune setup for MAF tuning with everything the guide mentions setup correctly. LTFT & STFT are not showing up.
The 60p injector tutorial talks about setting up two histograms (graphs with the new terminology I presume) and the AFR error has this weird formula that I can't replicate in the new version: [PID.6200]> 1.3. Do I need to have a different AFR error histogram setup when running 60p injectors? I've also setup the Injector Pulse Width graph with RPM on horizontal & MAP (kpa) on vertical but I don't really know what it means. I wanna make sure my injectors aren't messing with my afr numbers while i'm trying to tune the MAF.
And for logging, what's the best way to go about it? Should I only be logging when i'm gradually accelerating in one gear? Say I start off in 2nd, just run it gradually all the way up to redline & then stop logging?
I'm attaching my current tune & a log I just did at Idle, as I wanna make sure i'm properly setup first.
joel turbo h6.hpt2017-09-30 Log.hpl
