Results 1 to 3 of 3
Thread: TCC wont lock in a 08 Corvette
    May 2011
    5
    I'm working with a 2008 Corvette with a intake, cam, exhaust, and a 3800rpm stall. As of right now trans tune is pretty much stock. I've made some changes to see if I can get the TCC to lock up with no success then put them back to stock. Everything in the tune says it should be locking as far as the vehicle speed vs tps position tables ect. but it doesn't. It will lock when commanded to in the scanner.
    I've tuned other 6l cars with aftermarket converters and usually have problems with the TCC locking to much and having to adjust the tables so that the car drives well.
    Jun 2011
    Montreal, Canada
    758
    Post the tune.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,022
    are you commanding 100% in the minimum table? I have made that mistake before, and would not allow the tcc lockup, had to be 99% or lower
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
