Been messing around with my new build and have noticed a problem and am not sure whats causing it.
When idling in park, if i bring rpms up at all the truck will not return to desired idle, instead the truck will hang around 900-1000rpms till i either shut the truck off or shift into gear. If i drop it into gear it falls where its supposed to and when shifting back to park it will fall back to commanded.
i have been messing with the RAF a bit and it does not seem to help. I have pushed fueling around, messed with timing, seems to do the same thing.
I am posting a log, in the log i had just did a TPS/IAC relearn (voltage was about .65v before). i still have really high IAC counts and am wondering if that might be the cause. not sure how else to get the counts down as i am close to the voltage limit.
tune is a bit rough, just started the truck and have been tinkering with it in the driveway, yet to put any real miles on it.
2000 Silverado
02 156 OS with 3 bar SD
5.3l
stock heads
Proflo intake
Triple12 cam (212/212, 112LSA)
deka 80's
s480
4l80e swap
running OLSD all the time. no front O2's.
Tune - idle tuning 8-9-17 higher RAF..hpt
Log - Weird idle issue.hpl
Config - Snail wideband config.cfg
