6.0 random misfires???
I am tuning a 6.0 replacement in a 5.3 truck. The idle (have not messed with just yet) is a lil rough as far as vibration sometimes. Truck runs good and the stock engine is tuning easily except it keeps popping up a "RANDOM MISFIRE" DTC on the passenger side in cylinders 2 & 6 mainly. I'm pretty sure that's where the rough idle comes from because the truck is smooth as silk while driving. I have swapped coils and O2s side to side with no change whatsoever. Any suggestions???? Thank you anyone who may try to help me with this!!!
start with a crank variation relearn
you need to adjust the tables under misfire detection (under knock sensor) if you are using the 5.3 firmware on the 6.0. It will have a different rotational loads and will detect misfires because they are out of the expected parameters. I believe I found the highest reasonable value in the table and set the entire table to that value to cure mine. This has no effect on knock detection that I know of.
Thanks guys! I will look into that. I appreciate your time and help!
