Results 1 to 6 of 6
Thread: 2010 GT500 Cruise Control Issue
    Sep 2014
    N/A
    87
    Is there anything in the tune that could possibly prohibit cruise control from working in 6th gear? It works flawlessly in all other gears at any speed but it doesn't work at all in 6th.
    Jan 2013
    Hawaii
    2,102
    Engine speed and/or throttle position does not match the commanded positions. Log in a lower gear and compare to log in 6th.
    Oct 2007
    Crawfordville, FL
    2,447
    has the gearing in the transmission changed?
    Eric Brooks
    HP Tuners, LLC
    Sep 2014
    N/A
    87
    Quote Originally Posted by Eric@HPTuners View Post
    Eric, thank you! I was unaware that the 2007 TR-6060 trans that I just replaced my 2010 TR-6060 with had different 5/6 gears. Thank you for the heads up! I'll make the changes in the tune now.
    Jul 2015
    927
    We replaced the trans in a GT500, it was the one of the years that Ford got the gear ratio spacing wrong. The new trans had the proper gear ratios and caused all sorts of problems till I figured out what it was. Smart PCM for sure.
    Sep 2014
    N/A
    87
    Made the adjustments in the tune for the different gear ratios in 5th and 6th and still only have cruise control in 3, 4, and 5. Any other ideas would be greatly appreciated
